What is the best position for taking an enema?
The best position for enema is to kneel down on the floor with your buttock lifted higher than your head. This way the water goes deeper into your colon due to gravitational force and does more cleansing than in any other position.
In case you are suffering from knee pain or joint pain and can't get down on your knees, you may try left side position. Simply lie down on your left side with your legs straight out and bring your right knee up towards your chest. Now, use your right hand to insert the nozzle into the rectum and let the water flow in.
Furthermore, we recommend that you walk and massage your stomach with your hand in circular motion in the last few minutes of holding the water. This further aids the detox process.
    • What is the best time to take an enema?
      The best time to take the enema is early in the morning on an empty stomach after your normal bowel movements. But if that's not possible then you can do it at any other time. Just maintain a gap of 2 hours between your meals and enema and always ...
    • I am scared of taking enema, can I avoid it?
      We understand your concern. Taking an enema may feel a little intimidating at first. However, please take our word for it that it is a simple, safe and pain free experience. It is not as difficult or invasive a process as it may seem. Enema is a ...
    • Can we drink more water instead of taking enema?
      No, we don't recommend drinking an excess amount of water as a substitute to taking enema.  Drinking water does not have the same effect as taking an enema. Let's understand why. See, our primary aim with an enema is to dissolve the hard crusty layer ...
    • I don't feel any pressure after taking enema. Is this normal?
      Yes, it is okay if you don't feel pressure after taking enema. Oftentimes, the intestines absorb the water (especially when they are severely dehydrated) and start dissolving old fecal matter with that water. That water will eventually come out ...
    • I'm unable to hold the water after taking the enema. What should I do?
      If you are not able to hold the water, reduce the quantity of the water that you take for an enema. Start with taking only 100 ml of water and hold it for 5-10 mins. If this becomes easy, then move on to increasing the quantity of water the next ...
