I'm unable to hold the water after taking the enema. What should I do?
If you are not able to hold the water, reduce the quantity of the water that you take for an enema. Start with taking only 100 ml of water and hold it for 5-10 mins. If this becomes easy, then move on to increasing the quantity of water the next time.
Please remember that holding the water for sufficient time is more important than taking in more water. This is because the water needs to stay inside the intestines for long enough so that it can dissolve the hard & crusty waste stuck in the intestine walls.
Have you ever tried to clean a scorched pan?
If yes, then you must have noticed that we need to soak it in water for some time for the charred areas to soften, after which it becomes easier for us to clean the pan. The same holds true for the hard crusty layers of filth deposited on the walls of our intestinal tracts. We need to hold the water inside for at least 5-10 minutes so that this waste can soften up and can be flushed out.
Related Articles
Can we drink more water instead of taking enema?
No, we don't recommend drinking an excess amount of water as a substitute to taking enema. Drinking water does not have the same effect as taking an enema. Let's understand why. See, our primary aim with an enema is to dissolve the hard crusty layer ...
Water
Always drink as much water as required to quench your thirst! No more, no less. Drink water when you feel thirsty and eat food when you feel hungry. We are always confused when it comes to how much water we should drink. Here are some pointers that ...
I am scared of taking enema, can I avoid it?
We understand your concern. Taking an enema may feel a little intimidating at first. However, please take our word for it that it is a simple, safe and pain free experience. It is not as difficult or invasive a process as it may seem. Enema is a ...
Giloy Water
No, we don't recommend giloy water. If you are following the complete Satvic Lifestyle religiously, you will not require giloy water or any special drink to boost your immunity. Moreover, giloy is bitter in taste and anything thing that is bitter ...
I don't feel any pressure after taking enema. Is this normal?
Yes, it is okay if you don't feel pressure after taking enema. Oftentimes, the intestines absorb the water (especially when they are severely dehydrated) and start dissolving old fecal matter with that water. That water will eventually come out ...
